Problem with the wifi
carlos87
I’ve got a problem with the activation of my phone number. My lines are ok but I cannot use my internet service.
please, somebody can helpme?.
12 REPLIES 12
@carlos87
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and you can try to reset network settings on an IPhone
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit  Here link,
click Here link,
How to reset network settings on an Android device
  1. Open the Settings app on your Android.
  2. Scroll to and tap either "General management" or "System," depending on what device you have.
  3. Tap either "Reset" or "Reset options."
  4. Tap the words "Reset network settings."
   or visit  Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
carlos87
How can I check it?.
I need to check de vpn info?.
carlos87
Is a new number
carlos87
I’m talking about celular data.
@carlos87 wrote:
Yes is a new activation. But I couldn’t use the internet. It doesn’t function.
Just to be sure, log in to your account and check if the data shows up there as available.
carlos87
Thanks. I’m updating my Iphone.
carlos87
 @carlos87 : If Android then maybe post screenshots of the APN settings. If iPhone then connect to wifi and check for updates in About.
@carlos87 wrote:
I have a plan with data and I turned on the data on my cellphone and restart the networks settings
Is this a new activation? Are you porting in a phone number?
carlos87
 @carlos87 : Likely your APN settings. If you mean actual wifi then that's not Public Mobile. Public Mobile offers cellular data as the internet connection.
t_p
Do you have a plan with data?
If so, is cellular data turned on?
If you mean you're only using wifi and have no data plan, check if wifi is turned on and connected.
