Porting
ryanc1990
i can make calls but cant send or recieve texts for certain numbers. Ported old nunber.
Please help
apvm
I have issue porting my Petrol Canada mobility number to PM, sent PM to mod team, hope to get answer soon.  Tia
CS_Agent
@ryanc1990, Sorry to read about your service issue. I just sent you a private message, and will be waiting for your reply so that I can assist you.
Cheers,
Aïssata
KMG
You should send a private message to the Moderator Team - there is probably an issue with the porting of your number.
Effort
Did you just recently migrate your number?
Is your SMSC number 16475800172 ?
