08-31-2020 10:36 PM - edited 01-05-2022 01:01 PM
How long does it take to port a number from another carrier.
It has been 6 hours. Do I need to wait longer.
Joining Public
09-01-2020 08:19 AM
@mramos3102 if your port was from another cell provider. Then its probably stuck. Contact the moderators and ask them to fix it for you. There are 2 ways to contact the Moderator Team:
- Faster response- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
- Slower- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
09-01-2020 01:33 AM - edited 09-01-2020 01:38 AM
@mramos3102 honestly it only takes 2 hours to port a mobile number if done correctly. I just did 2 accounts today $2 baby! the first account didn't receive calls until about an hour and then texts came soon after. the accounts were with virgin. I also restarted the two phones and a network reset for each as soon as the sims were installed.
whats the make and model of the device?
try resetting your network settings
08-31-2020 10:48 PM
Try restarting your device.
08-31-2020 10:41 PM - edited 08-31-2020 10:43 PM
From what provider? Cell providers could be a few hours, landlines up to 7 days.
Did you do the port when activating ? Or selected a temp number? If temp number did you send a ticket to moderators to port your number?
Does anything work? Old account needs to be active and in good standing as well
08-31-2020 10:41 PM - edited 08-31-2020 10:45 PM
@mramos3102 wrote:How long does it take to port a number from another carrier.
It will take couple hours to 2 days. It depends on how quickly your old provider how quickly to release your number to PM.
You should be using your number on your PM SIM card. All incoming calls will go to your old SIM card until they release your number to PM.
Edit:
Porting a landline number will take up to 1 week to complete.
Data points: The following are my experience on porting times.
- Porting number from Rogers/Fido takes about 30 minutes.
- Porting number for 7-11 Speckout takes about 4 hours
- Porting number from Telus prepaid and Koodo postpaid is almost instant.
