Porting a home phone line is missing the account number field
03-31-2019 06:04 PM - edited 01-05-2022 04:04 AM
Hello!
I am trying to port over my in-law's home phone line to the PM line I created for it. The required fields I need to fill in are different for a home phone and the account number field is missing. I've filled in all the fields I can and am experiencing failure, I suspect from the lack of account number. Does anyone know anything about this? Thanks!
My Account
03-31-2019 10:18 PM
Please see my photos; the fields for porting a home phone line are different than the normal one for porting a mobile phone number.
03-31-2019 06:31 PM
As you can see in my most recent comment, the fields do not ask for the account number, which is probably the most important piece of information needed to port over the number.
03-31-2019 06:18 PM
I've attached an image for the fields it asks for, as well as the error message. Everything is filled in exactly as it is on the Bell Home Phone account. I think the fact that there is no account number field might be the issue. I tried both Chrome and Safari to no avail.
03-31-2019 06:09 PM
@MathewSuta , I am not familiar with the differences in the forms for a home phone number port. I can't imagine that Public Mobile would ask for information that is not availble to the customer. Generally the information is used to confirm rightful ownership of the number being ported.
03-31-2019 06:07 PM - edited 03-31-2019 06:12 PM
I ported my parents landline without issue. It took 3 business days before it started working properly. I see what you mean the account number is missing now. Not sure if it is an update issue or what is going on there because I'm pretty sure it was there before. If you have already started the porting process see if they can dial out on it. Either way I would assume it would be Tuesday or Wednesday at the earliest before the number actually will work properly (or will fail).
@MathewSuta wrote:Hello!
