07-02-2017 01:26 AM - edited 01-04-2022 02:16 PM
Seems to be a system glitch so requesting a mod to look into my accounts thanks
Transferred 3 numbers from Freedom Mobile to Public Mobile for promo plan
Text messages indictated ports were completed successfully
All 3 lines can make outgoing calls and send outgoing text
No incoming text at all
Incoming calls is strange; from ANY Public cell phone (including my older already activated lines) it gives a generic error about not being able to call long distance (despite all phones having same Toronto area code 647)
If I call from a non Public cell phone (eg my Telus cell) it just drops straight to voice mail
Help
10-21-2018 05:03 PM - edited 10-21-2018 05:05 PM
@scc wrote:hi - we just ported our number over from 7-11 speakout via a walmart associate. It also partially ported over. We have everything but call receipt. Call receipt from any outside number goes to voicemail directly.
We just sent a PM to the moderator. We haven't received our porting confirmation text though.
What is the current turnaround time for this? Thanks!
The number hasn't "partially" ported over. It either has or hasn't. When someone requests a phone number to be transfered to Public Mobile, the phone number is immediately assigned to the account. Outgoing calls will work immediatley. This does not mean that the number has been ported. In fact, at this point, the other carrier hasn't even responded to the request yet. This is part of the process and it's like this for everyone. With that said, porting a number from another wireless carrier is supposed to be done within a few hours.
The workaround is to continue using your Speakout Wireless service. The reason for all incoming calls going to voicemail would be because the Speakout sim card isn't inserted into a powered up device.
Assuming that you've provided the needed Speakout account details when you sent a message to the Public Mobile moderators, you'll hopefully see results within the next few days. The moderators would likely have to submit a new number porting request on your behalf.
10-21-2018 04:44 PM
Moderator waitimes have been 48-72 hours. If possible, can you still use your Speakout SIM/service until the port is completed?
10-21-2018 04:39 PM
10-31-2017 03:50 PM
@davidmj2008 wrote:I just transfered my phone number as well and am having the same issue.
I transfered my phone number from Virgin Mobile to Public Moblie 3 days ago. The ougoing calls work well. But If I call from a non Public cell phone , it just drops straight to voice mail.
I'm almost willing to bet that voicemail happens to be your old Virgin Mobile voicemail account. If that's the case, your phone number has not yet been transfered. I would just continue to use your Virgin Mobile service (if it is still working) until the moderators can fix this for you. Any time some calls you, calls would still be going there.
10-31-2017 01:19 PM
10-31-2017 01:14 PM
Please Help!
07-09-2017 09:19 PM
At the end of the day this issue has been escalated
Mods advised expect answer in 3 weeks
I did a number change on two of the lines (I can not wait nearly a month with no service) but will update this thread once ticket is resolved for the 2 remaining numbers
07-05-2017 12:10 AM - edited 07-05-2017 12:12 AM
I had sent this to Shazia but would love to see any other members test this out and provide feedback
As near as I can tell, the carrier exchange 647-915-XXXX is not callable by ANY Public Mobile subscribers in Ontario
I did a reverse lookup, found a few active Wind numbers (numbers that were never ported and I do not have any ownership of) and when I dial any of them it gives the generic error about can not call due to no long distance plan
So because these numbers are all in series (all good numbers in same exchange) it *looks like* port failed but in reality port has completed but the numbers can not dial each other
Anyone who can, block your call display and ring a random number for me ![]()
I would greatly appreciate testing / feedback
Thanks all
07-04-2017 03:27 PM
07-04-2017 03:25 PM - edited 07-04-2017 03:26 PM
I am assuming the issue is with your 289 number then? Can you please send me a pm with your phone number and the 416 number along with the others one that you cannot dial?
Thanks,
Shazia
07-04-2017 03:18 PM
07-04-2017 03:04 PM
Hey @kav2001c,
Sorry to hear about this,
I took a look at all 3 accounts and they are all provisioned properly.
Can you please test the phones again?
Thanks,
Shazia
07-04-2017 10:17 AM
07-03-2017 03:32 PM
@kav2001c wrote:@pakmode definately a port issue
Even without inserting SIM into phone if I call the number from an existing account (in service over 2 years on Public) I can not complete the call
Calling from a Telus number drops straight to voicemail always, regardless whether Public SIM in use or not
I'm more surprised no mod response yet, either here or in private messages
They must be very busy (2 days so 48 hours and waiting)
@Shazia_K is working today I think.
07-03-2017 03:10 PM - edited 07-03-2017 03:12 PM
07-03-2017 12:29 PM
Check your apn settings after doing a hard reboot.
Hopefully this gets fixed up soon.
07-03-2017 08:55 AM
12GB Promo seems to have worked properly
Now just waiting mods to push port through
07-02-2017 02:24 AM
07-02-2017 02:15 AM
@kentnleung Public sends TXT to the Public SIM as well as the refering SIM
07-02-2017 01:54 AM
i just transfered as well and am having the same issue.
when you mention you've received a sms telling you the port was successful, was it thru your freedom or PM sim card?
i currently have both sim cards and they are active - calls and data but no text at PM card, freedom works fine with text as well as others
