08-16-2019 05:49 PM - edited 01-05-2022 06:27 AM
Hi,
Transferred 2 numbers from koodo to the same account by accident. When I did this I lost the first number I transferred and want it back for my phone. Please help.
08-16-2019 07:56 PM
Called Koodo and they were able to correct my mistake. Thanks for you quick response.
08-16-2019 06:09 PM - edited 08-16-2019 06:10 PM
@LA21 I believe you can't have 2 numbers in one account, which is why when you added the 2nd one, it erased the first one. You need separate accounts for each number.
It takes aprox. 48-72 hours (2-3 days) to receive a response from a moderator.
08-16-2019 06:06 PM
@LA21You will hear back from them in about 48 hours +
08-16-2019 06:05 PM
Number was from Koodo. It transferred the first number over and it work but then transferred another number to the same account and it erased the first and it seems to be gone. I sent a private message. Hopefully it can be fixed. How long does it take to hear back from them normally. Thanks.
08-16-2019 05:52 PM
Did you do it while activating sim card or after when you already had account with pm set up?
08-16-2019 05:51 PM
Send a private message to the Moderator_Team! U can put urgent in the subject line and then explain your situation. Keep in mind that the wait time is upwards of 48 hours!
08-16-2019 05:50 PM
@LA21 wrote:Hi,
Was the number originally from Koodo or maybe Telus? Or did you bring it from another provider?
You'll need to contact the moderators who should be able to sort it out with the sister company.
@Moderator_Team < Click this.
