10-26-2018 11:00 AM - edited 01-05-2022 02:18 AM
Hello Can you help me to finish my porting process from my telus to PM ?
my PM sim card number is : 8912230000*********, and the number I am trying to port: 4********2
Edited by ShawnC to remove completed SIM and phone numbers for privacy
10-27-2018 01:08 AM - edited 10-27-2018 01:11 AM
@gough1 wrote:yes, I tried but it didn't work. please help
You can edit your own posts. See those 3 dots in the upper right of posts. Click on it in your first post and select Edit Reply and you can edit your posts.
So did you try your prior Telus SIM?
If it no longer works did you try your new Public Mobile SIM?
If it does still work then you could use that until the port finishes or that you get a reply back from the moderators. You did send them a message right?
10-27-2018 01:00 AM
10-26-2018 11:06 AM
@gough1 please remove your personal info.
if you have a stuck port only mods can help via private message
in the mean time use your telus sim card.
How can you get help with your account, activation, or service?
In your message please include:
If you have a Porting issue, please also include:
Don't know your pin?--provide any 3 of the following:
How long until they reply?:
Additional Useful Information:
10-26-2018 11:05 AM - edited 10-26-2018 11:11 AM
@gough1 wrote:Hello Can you help me to finish my porting process from my telus to PM ?
my PM sim card number is : xxxxxxxxxxxx, and the number I am trying to port: xxxxxxxxxx
Hi and welcome. Please remove your personal information. Anyone on the internet can see this post.
Have you attempted to port through the self serve yet?
