Plans
JD59
Is the 20gb plan for $29 available to me in Alberta
2 REPLIES 2
TheSterlinger
The $29 20GB 4G data plan is only available to new customers. If a plan is for a certain province it will say specifically or when you go to sign in it will be missing from the options.
That being said you can submit a ticket to a Public Mobile CS agent and see if you can get the plan.
Sansan
When you sign into your account  whatever is available is listed. If you do not see it that means it is not.
