Plan change
hahmed7588
Hello, my phone was on suspend because I hadn't topped up in a while. However I topped up and want to change the plan and there is enough money to cover it but it won't let me change it and my phone number will be lost as of October 23rd please help!!
1 REPLY 1
NDesai
@hahmed7588 Send a private message to the Moderator_Team with your ph#, account# and your pin. Since you cannot change your plan while account is expired, they will have to change your plan from their end.
