Plan change down
04-12-2021 10:36 PM - edited 01-06-2022 01:45 AM
I keep getting an error every time I click on the plan change tab and my amount owing isn’t showing up. Is this happening for anyone else?
My Account
04-12-2021 10:51 PM
I just checked and everything seems ok
04-12-2021 10:49 PM
@nathfreder1 this happens regularly. check back in an hour or so
04-12-2021 10:46 PM
It looks like there might be an issue with having all data accessed and processed properly. Are you on a mobile device (like an iPad?).
A few things to try:
- Clear all history/cache/cookies and try again
- Disable any ad-blocking/cookie-blocking features/programs
- If you're in a Private/Incognito session, try using a normal session
- Try a different web browser
- Try accessing your account on a different device
If you have any more details to share with us - steps you take/etc, then we might have a better idea with other suggestions to try. 🙂
04-12-2021 10:38 PM
Try a different browser.
