Phone problems
08-23-2019 07:37 PM - edited 01-05-2022 08:39 AM
My bill is paid but I don't have 4g without WiFi can't use most of my apps without WiFi sum1 plz help
Service
08-23-2019 07:41 PM
What plan are you on, and is it a new plan or old one?
08-23-2019 07:41 PM
@Dis_guyy1 wrote:My bill is paid but I don't have 4g without WiFi can't use most of my apps without WiFi sum1 plz help
Which phone are you using?
Restart your phone with your new PM SIM card inserted to let PM SIM to initialize your APN.
If your data is not working, you need to setup your APM setting manually.
08-23-2019 07:40 PM
Try restarting phone and resetting APN manually, you can read about a similar problem by clicking this link:
https://productioncommunity.publicmobile.ca/t5/Getting-Started/data-wont-work/m-p/413618#M80501
