Phone numbers
2kewel
I have a ex boyfriend that is harrasing me he has callled or texted me from over 100 burner numbers, i need to change my number but because i had already done it not that long ago it wont let me. Is there a way to do it or someone i can contact to let me do it sooner?
2 REPLIES 2
2kewel
Ok thank you
kselmak
@2kewel
Send private message to Moderator_Team
Click on the little envelope in top right corner
You can port in numbers as frequently as you want, but VoIP numbers take a week
I suggest you get yourself free Fongo or TextNow backup number as well and use it while you wait for the switch screen all unknown calls
