Phone number
02-01-2019 11:31 PM - edited 01-05-2022 06:35 AM
How do i change my phone number from my public mobile sim card to my new activated public mobile sim card?
Service
02-02-2019 02:02 PM
Change a new SIM card that has already been activated, to another PM number, would need to be a new number from the system, as a PM can not be moved to another account. This has been mentioned previously, and the Moderators have be instructed to not do this switch any longer.
The only way to get it onto your new SIM, is to port the number to another carrier, and then port it back in PM on your new sim.
02-02-2019 10:38 AM
New SIM card would do it
02-02-2019 02:53 AM
If you're looking to change the SIM card associated with your account:
Go to "Change SIM Card" located at the bottom right on My account page. (Not sure if this link will work, once you're logged in) https://selfserve.publicmobile.ca/Overview/plan-and-Add-ons/change-sim-card/
If you're looking to change your number:
Go to "Change Number" located at the bottom right on My account page. (https://selfserve.publicmobile.ca/Overview/ChangeNumber/)
This section also lets you pick a number from a drop-down list or gives you the option to port your number (takes about 2 hours for transfer to occur)
D
02-02-2019 01:36 AM - edited 02-02-2019 01:37 AM
@Cocainecowboy wrote:How do i change my phone number from my public mobile sim card to my new activated public mobile sim card?
Is there a reason you activate another sim card even though you already had a self-serve account? You could've just changed the sim card as mentioned above. But if you activate another sim, you must've paid for your new account. I am pretty sure PM to PM number transfer is not allowed.
02-01-2019 11:35 PM
02-01-2019 11:35 PM - edited 02-01-2019 11:36 PM
I'm not sure about the sense of the question but you can go into your self-serve and use the Change SIM feature to change your SIM card.
But what is the exact scenario you're looking at?
