09-21-2019 05:35 PM - edited 01-05-2022 07:13 AM
Hi,
I know my phones IMEI. Where can I find if its compatilble with PublicMobile?
09-21-2019 07:02 PM
@kalfiThere is quite a few variations of Redmi 6. It would be extremely useful to find out which variant you have. What works and what don't work? Also swap your SIM card to another phone like a Samsung to see if your SIM card has been activated correctly.
09-21-2019 06:55 PM
@kalfi wrote:It is Xiaomi Redmi 6...it says should work but it doesn't
Seems to be light on the LTE side, but 3g looks good. Set your phone to 3g until you get it working to eliminate some issues.
09-21-2019 06:51 PM - edited 09-21-2019 06:56 PM
09-21-2019 06:00 PM
09-21-2019 05:42 PM
@kalfi wrote:Hi,
all Current Canadian and Phones from the last 6 to 7 years will work with PM as long as they are unlocked
09-21-2019 05:38 PM
Don't post your IMEI.
Willmyphonework.net will tell you with make and model number.
What kind is it?
09-21-2019 05:38 PM
@kalfi it used to be on the get started page but I can't find it right now! You can check willmyphonework.net
To see
