10-14-2020 02:59 PM - edited 01-05-2022 03:44 PM
10-14-2020 08:17 PM
@Luddite wrote:FYI: my understanding is that one must first enter 1,2,3,4 to ready a new SIM to accept a locking code. If you've already made 3 attempts then you need a PUK. 😩
Your understanding is correct. The SIM card PIN couldn't possibly have even changed without the default 1234 first being entered (at least by someone even if it's someone else).
10-14-2020 03:25 PM
@hopeboom "made a few too many attempts to lock the sim and it ended up locking the phone "
Be aware that entering a PUK incorrectly 10 times renders the SIM useless.
If you have a spare SIM you could use it to replace the current SIM by logging into your account.
10-14-2020 03:10 PM
@hopeboom contact customer support mods
click on the question mark chat bubble to the bottom right of your screen
type "PUK code"
(use the chat bubble options, then click "submit a ticket, click me" option)
*login using your community account
make sure to check your inbox(top right corner envelope icon) periodically, for a response
10-14-2020 03:08 PM
I made a few too many attempts to lock the sim and it ended up locking the phone
10-14-2020 03:02 PM
@hopeboom That is unlikely, unless you are attempting to lock your SM.
Reboot your phone with the SIM installed and report the exact message.
