PUK code
09-09-2020 09:02 PM - edited 01-05-2022 01:09 PM
09-09-2020 10:37 PM
@computergeek541 , noted - thanks!
09-09-2020 10:33 PM - edited 09-09-2020 10:38 PM
@esjliv wrote:Hi @Noelan26 ,
Some ways to obtain it.
See here:
https://www.digitalcitizen.life/get-puk-code-sim-card
On that website, it says to use one of 3 methods:
1. "Get the PUK code from the SIM card packaging"
2. "Sign in on your mobile carrier's website to get the PUK code"
3. "Call your mobile carrier to get the PUK code"
None of the above methods will work. The PUK is not on the packaging of Public Mobile sim cards. There also isn't any way to view the sim cards's PUK in the self serve website, and there's no way to call Public Mobile since there is no call centre.
09-09-2020 09:48 PM
@Noelan26 wrote:I sent the ticket
I got a response but how do I reply back?
there is no reply button?
Click on the envelope in the upper right of this window. That is the private message system.
Click on the subject line of the message to fully read it.
There you'll find a reply button.
09-09-2020 09:45 PM
It says
enter your PUK code and on my SIM card there is nothing
09-09-2020 09:42 PM
I sent the ticket
09-09-2020 09:20 PM
@Noelan26 if it's a network unlock pin then contact Samsung
if it's a 8 digit sim PUK then contact customer support
click on the question mark chat bubble to the bottom right of your screen
type "PUK code"
(use the chat bubble options, then click "submit a ticket, click me" option)
make sure to check your inbox(top right corner envelope icon) periodically, for a response
09-09-2020 09:18 PM
Hi @Noelan26 ,
See here:
09-09-2020 09:02 PM
@Noelan26 wrote:how do I get my PUK code?
What exact message is your phone giving you to want a PUK code?
