Original Call Number Error
madden
Anyone who tries to leave me a voicemail gets a OCN error. Can PM manually set up Conditional Call Forwarding for me?
8 REPLIES 8
madden
That's right. Works perfectly on friend's PM account. So I know there is a back end solution.
madden
Thank you!
madden
The thing is ocn was correctly setup for second line. I believe because the number was ported from TELUS. Point being there is a technical solution on the back end. The question is will PM process it?
@maddenUnfortunately I don't think Public Mobile supports OCN.
Here is the link that provides more information https://productioncommunity.publicmobile.ca/t5/Public-Lab/OCN-original-called-number-packet-support/...
@madden
madden
Thank you. I already completed the codes and that is how ended up with the OCN error. The carrier needs to manually set up the conditional call forwarding to resolve the issue.
geopublic
@madden  Click here for  info on how to setup call forwarding.
cavemantoronto
Are you trying to use Youmail?
