11-02-2016 08:29 PM - edited 01-04-2022 04:13 PM
I have installed LTE discovery app on my OnePlus One and it shows average signal strength on band 4 as -115.0 dBm. I don't understand if it's a fair or good strength.
Also, average LTE speed shows as 18.9 Mbps DL and 3.8 Mbps UL. Is it a good speed?
Any one got better speed with this model on PM anywhere in or around GTA?
It shows 4G on top right instead of LTE. Is it normal for this model?
11-03-2016 09:01 PM
@ION9 wrote:Yes, the first time I connected to PM I had to set them manually because my Internet was not working.
But technically speaking 4g is better than LTE. 🙂 Long story short, LTE was the first generation they branded as 4g. While being faster than 3g it wasn't fast enough to qualify for 4g.
You could however try looking in your "Mobile network settings" for "Preferred network type". I have 2g, 3g and LTE(recommend) listed.
Do you even have LTE listed?
No, 4G is not better than LTE. Not in the real world because we don't have true 4G network. So, if your phone shows 4G, it's either LTE (good scenario) or HSPA (bad scenario).
So let's be clear, you are never ever better off with your phone showing 4G and not LTE.
11-03-2016 08:39 PM
@Mintoo It doesn't show as option in network settings. Only options for my OS version are: 2G, 3G and 4G (recommended).
11-03-2016 08:31 PM
11-03-2016 08:26 PM
@Mintoo wrote:
I'm running my OPO on CM13 and it says LTE. I get around 40-60 in the GTA. Latest test was 60
That's very good speed. Not sure why 13.1.1 shows as 4G though.
I wish to see 60Mbps DL speed in certain locations at least.
11-03-2016 08:09 PM
11-03-2016 05:59 PM - edited 11-03-2016 06:02 PM
@ION9 Nice to see your data settings. Mine doesn't show LTE. It shows 4G. Could be due to Cyanogen OS version.
All,
I tried speed test outdoors in Toronto and got 40.5 Mbps download and 23.3 Mbps upload.
Happy to see this on OPO as it cought up with today's tech as far as LTE chip is concerned.
11-03-2016 08:43 AM
Here are my APN settings of you're wondering.
11-03-2016 08:32 AM
11-03-2016 05:54 AM
My OPO is on Android Marshmallow CyanogenOS 13.1.1
APN settings were automatic and I did not change them.
Did you change? @ION9
11-03-2016 12:50 AM
11-02-2016 09:21 PM - edited 11-02-2016 09:22 PM
@nmr wrote:It's indoors but not a concrete building
You might be far from the tower. There are many possible reasons.
How is it when you are outdoor? At various locations?
One thing to remember also is the LTE band used can have an impact. You said band 4, this is high frequency. It means it doesn't travel through walls (especially concrete, but it's not the case at your home) as well as lower frequencies.
All I'm saying is that unless you get a much better signal by putting the SIM into another phone, I wouldn't worry. I'd suspect the OPO to have an average radio (hey, they couldn't have high-end components everywhere).
Did you use to have a better signal with your previous provider?
Finally, if this is when you're at home, you could try to force the phone to switch to 3G. I'm sure your signal will be stronger and I imagine you have wifi for data at home. But honestly, as I said, if your connection is stable, don't worry about it, it's most likely perfectly normal.
11-02-2016 09:16 PM
11-02-2016 08:55 PM - edited 11-02-2016 08:57 PM
@nmr wrote:I have installed LTE discovery app on my OnePlus One and it shows average signal strength on band 4 as -115.0 dBm. I don't understand if it's a fair or good strength.
That's a fairly weak signal. But it doesn't mean there is anything wrong with that. Is that indoor? Do you live in a concrete building? I get this reception in mine because the tower is on the wrong side of my building.
As long as your connection is stable and your data is fast, it's fine. Some phones have better radio signals than others, but I don't remember the OPO to be known for weak radio signal.
11-02-2016 08:45 PM
ok... it should soon display LTE ...as explained...we had a few people with the same question/issue, and after a short while the phone started displaying LTE ... but again, each phone is different..some show LTE..some show 4G ...some shoe LTE+ ( which is advanced LTE ) some show 4Ga ...as long as the speeds are up to snuff....
11-02-2016 08:42 PM
I don't use an app to get LTE. I used it to confirm if I am getting LTE bandwidth as it shows 4G.
11-02-2016 08:34 PM - edited 11-02-2016 08:36 PM
and 4G is actually LTE .... 4g is refered to as the industry standard and LTE referes to the bandwith used..it eventually will display LTE sooner or later....
cheers
11-02-2016 08:32 PM
hi..
i guess that is considered a good speed considering you use an app to get lte.... 18 mb/s is very decent......
