Not receiving texts
ashishg1
Hi, I am unable to receive texts and it appears everyone is receiving texts from me just fine. I recently bought US roaming bundle and it seems like people do have issues with that when it expires. Can someone please assist. I did mail moderator team however no reply and this is fairly urgent issue as to work i need MFA and just so happens its trying to send a text on my phone! Thanks
11 REPLIES 11
That totally makes sense:)
Thanks @srlawren
srlawren
@totalUser wrote:
Hi @srlawren
Here is the one mention of turning on the roaming and restarting the phone, but that is not the one i originally saw.
https://productioncommunity.publicmobile.ca/t5/Discussions/Not-Receiving-any-text-messages/m-p/46781...
@totalUser I would suspect the "restarting the phone" is what got the texts flowing again, not turning on roaming.  Sometimes restarting is necessary after the expried add-on falls off (though for many people the texts just start without it--that was always my experience).
Hi @srlawren
srlawren
@totalUser wrote:
Couple of days ago somebody mentioned after turning on &off roaming and restarting the phone they had a bucket full of messages poured into their inbox
@totalUser this actually makes little sense.  In the past at least, every single message sent to you during that "up to 24 hour" window between the add-on expiring and the expired add-on falling off your account was completely lost and never delivered (nor any indication sent to the originator that it was not).
Hi @srlawren
I'll try to find it in my browsing history
Toggling on and off roaming then restarting was mentioned yesterday
Stay Safe!
srlawren
@totalUser wrote:
@ashishg1
Some people managed to have it working by enabling the roaming while back home
@totalUser they did?  Admittedly I don't (and can't) read every post on every thread in the community, but I don't recall ever seeing this mentioned before.  Do you have any links handy where people have said this worked?
GaryW
You might also check your APN settings, which should be as follows:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password:  Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,supl
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
PAULRANG18
This issue doesn't seem to go away. Hopefully, PM gets a handle on it soon.
totalUser
@ashishg1
Some people managed to have it working by enabling the roaming while back home. If that doesn't work, it will just take time.
It should resolve by itself, to speed it up the only other thing you can do is talk to mods and wait for their (hopefully fast) reply.
ChuckYeah
I believe time, or @CS_Agent help is the only known solution!
