09-21-2020 10:03 AM - edited 01-05-2022 03:58 PM
I recently updated my plan to the $15 one and it is set to change next billing cycle (October 16th I believe). Since making the update I lost service and I think it is related. How do I get my service back. When I check my account it still shows I have the $30 plan. Currently getting an error "no service".
09-21-2020 01:01 PM
If there’s something wrong with the SIM card or your phone’s settings, which might be the case, it’s better to visit a physical location near you, like in a mall, so that they can check it for you. That’s what I would do.
09-21-2020 11:14 AM
There is no need to get replacement sim, moderators will be able to revert it back to the original sim card.
It's important that the phone is reported lost/stolen until then
Your password must charge too it they will be able to cancel your suspention.
Your security questions must change as they can easily be read in your selfserve
09-21-2020 11:05 AM - edited 09-21-2020 11:06 AM
@johnsk5 wrote:the sim number is indeed different from what is found in my phone.
@johnsk5 You're saying the last 4 digits of the SIM number on your account don't match the same digits on your actual SIM card?
Then someone else is using your phone service. Please go on your account and declare your phone as lost/stolen to suspend service. Then change your password. Also check the text/call log on your account to see what the other person has been doing, they may even get access to your other accounts via 2FA.
You'll need to get a replacement SIM card, and change your account to the new SIM to restore your service.
09-21-2020 11:01 AM
@oglat wrote:If there were charges to the account you typically need to restart your cell.
If that is bit working you may need help from mods https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Also every time you downgrade you are at risk of autopay not executing properly. My advice is once you resolve this issue you should pay manually the amount for the previous plan so that you avoid common autopay problem. You will still get all the rewards and the excess money will stay on your account for future payments.
@oglat See the OP's reply immediately above yours. He has bigger issues than this.
09-21-2020 11:00 AM - edited 09-21-2020 11:03 AM
I missed your last post
That is attempt of account theft
Contact modes asap
They will be able to revert the change
You must
Charge your password and security question
You must report your phone lost until mods resolve this
You must charge your name on file if they try to port your number.
Check your banking situation too
09-21-2020 10:59 AM
09-21-2020 10:57 AM
09-21-2020 10:38 AM
Hi @johnsk5
Based on the info that you've provided so far, your account looks fine.
As mentioned by others, do try restarting your phone.
Here are a few more things you can try:
1. Test your SIM card on another phone. This can tell you if it's a hardware issue or if there is a problem with the SIM/phone service.
2. Call 611 and listen to the message. What is your account status?
3. Check to see if your phone has been blacklisted.
09-21-2020 10:23 AM
@johnsk5 That is a normal thing to see. You don't owe any money.
09-21-2020 10:22 AM
@johnsk5 did you register with pm before April?
login to your self serve account and click on "change sim" make sure the last 4 digits match the sim card in your phone. if it doesn't match then someone is commiting fraud.
click on the question mark chat bubble to the bottom right of your screen
type "security or identity fraud issue" or "no service"
(use the chat bubble options, then click "submit a ticket, click me" option)
*login using your community account
make sure to check your inbox(top right corner envelope icon) periodically, for a response
09-21-2020 10:20 AM
showing:
09-21-2020 10:14 AM - edited 09-21-2020 10:15 AM
@johnsk5 Why would you think you owe money if you just paid for 30 days? If you owe money your account status in self serve will say Suspended. Otherwise it says Active. What does yours say?
09-21-2020 10:10 AM
I think my account is the issue. It thinks I owe money I believe. I just paid on September 16th and should be good until October 16th which is when my new plan is supposed to take over.
09-21-2020 10:07 AM - edited 09-21-2020 10:09 AM
It should not affect your service at all now, it is most likely a coincidence
Can you restart your phone, maybe keep it off couple of minutes
Is your status active? Did you suspend the service for some reason? Does your sim number match the last 4 digits of sim number in your account? Are you on airplane mode by accident
