No network
09-18-2020 09:19 PM - edited 01-05-2022 01:15 PM
I bought a sim card from retailer and he told me to activate it my self and I did but no network it's not working.
Joining Public
09-19-2020 12:33 AM
@Zee21 wrote:Thnks but stil not working
I wonder that you might have mis-typed the SIM #. Unfortunately we can't see all the numbers but we can see the last 4 digits. Compare the self-serve Change SIM function to that on the actual card. Don't change anything...just look. I don't know if there is any error correction on entering a SIM # if you did.
Do you have another phone to put the SIM in and see?
Can you manually search for networks and see if Public Mobile shows up?
Can you verify that the phone isn't looking just for GSM? Preferably something like LTE/UMTS or WCDMA or HSDPA or 4g or 3G.
09-19-2020 12:27 AM
09-18-2020 11:10 PM
@Zee21 try resetting your network settings
1. Open Settings>General Management>Reset
2. Tap Reset Network Settings>Tap Reset Settings
If prompted enter your pin, passcode
3. Tap Reset Settings 1 more time to confirm
4. Restart
09-18-2020 10:54 PM
Samsung s8
09-18-2020 09:26 PM
Make and model of phone?
09-18-2020 09:25 PM
Can you test it on different phone
One that for sure works on telus network.
Can you access your selfserve account?
09-18-2020 09:20 PM - edited 09-18-2020 09:21 PM
@Zee21 wrote:I bought a sim card from retailer and he told me to activate it my self and I did but no network it's not working.
Top of page, click Get Started to begin with.
Also make use of "Live Chat".
