No mobile network
LLEDNARC
I have tried restarting phone
Removed simplicity re installed
Airplane mode on/off
Even manually selecting a network public mobile doesn't show up at all and selecting tells isn't working either
1 REPLY 1
slusagm
you can't use Telus as it is a PM sim card
do you have another phone to test the sim card?
or ask PM to help.
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA  code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.)    When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
(if you can't 2FA code on SMS to login and submit ticket, click Didn't Receive code and choose Send email)
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox,  between 9AM-10PM EST (Mon-Sun), check here:
