04-20-2019 03:36 AM - edited 01-05-2022 04:29 AM
04-20-2019 07:44 AM
@Section wrote:I don't know about the settings but I'm on the $50 a month plan 8.5gb because I'm on auto-pay it says that I have used 2.67gb and now the mobile data says it's used
If your account is in active status, the overview tab, plans and add-on section should give you a meter reading of the remaining data for the renewal period. If nothing shows there about data, that means it is all used up. Alternatively, the renewal could have glitched. Generally, if the account status is active, it indicates a successful renewal.
04-20-2019 05:42 AM
04-20-2019 03:54 AM - edited 04-20-2019 03:55 AM
@Section wrote:Hey why is there no mobile data whrw it renews on the 17 th
Are you sure you have data left? if the data isn't showing on the OVERVIEW Page (when you first sign into self-serve), then it has been used up for your current cycle. Conventional thinking would suggest that the system display the data still showing 100% consumption. Unfortunately, the self serve is programmed to remove reference to data when it is all used up. If you don't see the data list in your plan details (I believe it's the Plans & Add-ons page), then you have an account issue and will need to contact the moderator team for assistance.
If you still have data left then go into network settings and make sure "mobile data" is enabled. Restart your phone. Turn air plane mode ON then OFF. Do you have another phone to try your sim card in to see if data is working? Has data ever been working? Have you tried data on more than 1 app, have you confirmed you have no local data restrictions / firewall settings? Go into mobile data usage under settings and make sure you have not used your local "data limit" and there are no network restrictions
Go into network search and try reconnecting to the network and make sure LTE is set to preferred (even if you have 3g) If was already on LTE, then try switching to 3G, did it help? No? Then go back to LTE.
Does MMS work? (Not SMS) MMS uses data. Try sending a picture to yourself. Did you get it?
The most likely cause is the APN. You need to configure (Or re-configure even if you have already configured before) your APN settings to be able to send pictures (MMS) and navigate on internet (DATA). Your "Mobile Data" needs to be activated.
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Iphone
Settings > Cellular > Cellular Data Options > Cellular Network
OR
Settings > Mobile Data > Mobile Data Options > Mobile Data Network.
Name: Public Mobile / Mobile Internet
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Select Save/Done. Select Public Mobile to connect to the Public Mobile network.
04-20-2019 03:54 AM
Are your APN settings correct? Can you give us some more info, which plan are you on, do you have any data remaining this month?
