No data, even after checking APN. Please help
ajoke70
@ajoke70  APN should be sp not so:Smiley Happy
Change so.mb.com to sp.mb.com and you should be good to go.
ajoke70
275124D5-A5FC-46FE-BB08-855CD2050CF6.jpeg8D9D6CDF-A7C4-47FC-909C-35584C084CD6.jpegDBED1C5C-7E90-40B7-AE00-9152E7EAE1B7.jpeg
geopublic
@ajoke70  Can you post a screenshot of your APN settings.
Tony8
Hi, Make sure your Data is on. If it still does not work, recheck the APN for a typo. I had one, i entered it wrong. You might have to erase all the old APN to Default and start again.
