06-19-2020 07:10 PM - edited 01-05-2022 11:46 AM
Signed up today and phone says no service, phone is an iphone7, and unlocked. Went for a 20 mile drive, no service anywhere?
Joining Public
07-28-2020 10:55 PM
@geopublic thanks, restarting worked. Appreciate your help!
07-28-2020 10:40 PM
@bungy57 wrote:I’ve had this account for over a year and now it’s indicating no service.
Hi @bungy57 ,
Please go to "Ask a Question" in the below link, and describe in detail the issue you are having.
https://productioncommunity.publicmobile.ca/t5/Using-Your-Service/bd-p/Discussions
Thanks
07-28-2020 10:40 PM
@bungy57 try restarting your phone or toggling airplane mode on and off.
07-28-2020 10:32 PM
06-27-2020 11:43 AM
PM have me up and running, said it was a back end problem. I had tried many of the other suggestions to no avail, thank you all.
06-19-2020 09:20 PM
@samibaltzer wrote:This also happened when I first switched and I had to reboot my phone to receive signal 🙂
Reboot is needed because of the new phone design.
Roughly before 2013 or earlier, phone battery were removable and the SIM card were under the battery. Therefore, back then, you need to remove the battery(i.e.phone off) in order to change your SIM card. For the old phones, there is always a phone reboot in order to change SIM card.
New phone does not have removable battery any more. SIM card can be hot swamped with phone stay on. Therefore, we need to manually reboot our phone after changing SIM card.
06-19-2020 09:07 PM
06-19-2020 08:11 PM
Listen to @geopublic and @gpixel and contact the moderators. Customer support has been quick lately....expect to be contacted within a couple of hours at the latest.
06-19-2020 08:02 PM
@JohnWWW you can contact customer support here
https://www.publicmobile.ca/en/bc/get-help/articles/contact-a-moderator
make sure to check your inbox(top right corner envelope icon) periodically, for a message
Moderators are available from Monday to Friday from 8AM to Midnight EST and from Saturday and Sunday from 8AM to 10PM PM EST
06-19-2020 07:59 PM
@JohnWWW It's possible that your account wasn't provisioned properly and needs to be reset by PM. Submit a ticket to PM and ask them to check your account.
06-19-2020 07:21 PM
Did you port your number in on activation? Are you 100% sure your phone is unlocked? Did you recieve any error messages?
06-19-2020 07:18 PM
Welcome to pm @JohnWWW . Try these 2 things
- sync to iTunes
1. Insert new working SIM - do not turn phone on (if SIM is already in, turn off)
2. Connect to computer with USB cable.
3. Start iTunes if it doesn't auto run
4. iPhone will switch on. Wait until iTunes registers it and checks for updates
5. Install the carrier profile update (if offered, if not, go to step 6)
6. Disconnect and restart. From @luddite. - Reset your Network Settings.Go to Settings > General > Reset > Reset Network Settings. This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APNsettings that you've used before. Restart your phone if it doesn't automatically. If it works. Enable data and sms and mms to send and receive from Android phones.
Stay safe.
06-19-2020 07:14 PM - edited 06-19-2020 07:20 PM
Have you registered/activate the sim successfully? If so, try restarting your phone.
