No Service Now after Porting
srogers
Ported Number on Saturday, was working after @Mary_M resolved porting issue, now we you call the number it says number is not in service. Had similar problem when porting another number from telus couple weeks ago.
iamleoliu
I am having the same issue as you did. Hopefully it can be resolved. @Shazia_K
srogers
@Shazia_K worked to help get this resolved all working again.
srogers
Defintely tried the usual, reseeding the SIM, power off and on..I noticed now that my telus account is now closed when i sign on to it where i was able to yesterday. Also like i said when you call the cell number it says its no longer in service so i think its a telus/PM issue.
Sameer
Doesn't hurt if you didn't try, pull out your sim and reboot phone and see if any of that fixes it. Otherwise, yeah you will have to wait for a mod.
daredogg
@srogers Usually there are no issues porting from Telus, so I am surprised to hear of yours. Hopefully it's something quick and your service is restored once a moderator checks it out.
neilselden
Hi,
Sorry to hear that you're having troubles.
This is definitely a job for one of our moderators.  @Shazia_K, can you help out @srogers?
Cheers,
Neil
