New mobile plan
Jessikasankey
I just switched to public mobile and have unlimited talk across Canada, unlimited text and 6gb of data and the phone works but the data did not start up ... I've done factory reset on phone and still nothing.  What do I do to get this fixed
10 REPLIES 10
srlawren
@Jessikasankey here's a couple of related threads on Zenfone 3 (and variants) you may want to check out:
https://productioncommunity.publicmobile.ca/t5/Getting-Started/APN-settings-for-ASUS-Zenfone-3-Zoom/...
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Asus-ZenFone-3/m-p/151826/highlight/t...
It sounds like you will need to delete any existing APNs and create one from scratch, entering the values (carefully) manually.
will13am
Here is an external site covering APN set up for the phone.
https://apn-canada.gishan.net/en/apn/public-mobile/asus-zenfone-3-ze552kl
@Jessikasankey
Ensure you have the correct APN settings by visiting https://apn-canada.gishan.net/. Select the brand and model of your phone, scroll down the page and then select Public Mobile. After doing so, you will be provided with the exact APNs required for your phone on our network.
Jessikasankey
mimmo
@Jessikasankey the link I provided should have the needed info.
@wetcoaster. I had tagged one as well but with all the changes in the KB.  I think one of the new articles links to an external site with Apn info but finding it on phone is hard.
Jessikasankey
Asus zen3
@mimmo wrote:
@srlawren wasn't there an official Apn setup guide somewhere?
@mimmo
There used to be a KB article about trouble shooting data access problems including APN settings. I have just spent 15 minutes searching for it but can't seem to access it with any of my links or searches.
mimmo
srlawren
@Jessikasankey what's your phone's brand, model, and operating system verison?
mimmo
Did you set up your Apn ?
For a good read(s) on this topic search for *apn* and PM-GUIDE (remove "-" during the search)
Edit I can't find the exate link with all the Apn Info. Others will post it. Have patience 🙂
This is one of them https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-setup-data-and-APN-on-my-And...
