New Plan
EhsanTar
Hi,
I was a public mobile customer, but now I use another provider.
I wanted to buy a $23 plan now but it shows $50 for checkout.
Are the announced prices fake?
Thanks,
Ehsan
Just create another Gmail for free
Or ask PM to check why you don't see the new Activation plans even you left already.   Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
EhsanTar
I don't have other emails.
Is there no way to remove my previous account from Public Mobile and resubscribe?
Sansan
All prices are listed correctly on the website.  The lowest i see is $23 for 2.
If you mean that you want to lower your plan to a cheaper one, then yes, you might not see anything less than $50.
Plans on the main web page is different from that of current customers.
slusagm
Hi @EhsanTar you should see the $23 plan if you come back as a new subscriber
Try create another account using a different email address and check Subscription page again
