03-16-2020 12:20 PM - edited 01-05-2022 09:57 AM
I am planning on getting a new phone (iPhone 7 128gb) and was going to check the compatibility in the getting started section. The dropdown to select phone and model are not working, is anyone else getting this problem?
03-16-2020 12:25 PM
@Max_Murphy the compatibility checker is down. But according to this, https://apn-canada.gishan.net/en/apn/public-mobile/apple-iphone-7 your IPhone 7 should be 100% compatible. Providing its one of the 6 submodels listed there.
03-16-2020 12:25 PM
Thanks
03-16-2020 12:24 PM
Thanks for the reassurance
03-16-2020 12:22 PM
@Max_Murphy No worries, your phone will work perfectly with PM.
03-16-2020 12:22 PM - edited 03-16-2020 12:25 PM
Your phone will work. Ensure it's unlocked.
And the compatibility link has been having issues it's up and down.
