New Phone
QuilterON
I am purchasing a new Galaxy phone with 5G capabilities.  Do I need a new SIM card.  Do I need a new plan?  I currently have a Samsung A50
2 REPLIES 2
@QuilterON
The Samsung A50 is not v20 VoLTE compatible nor has 5G.
If you are looking for a New Samsung. Get the Samsung A15 or newer or the S22 or newer. Enter the IMEI to see if it is compatible. Here is more information on VoLTE.
https://www.publicmobile.ca/en/get-help/articles/volte
NDesai
@QuilterON No, you don't need another plan. For SIM, it depends what phone you are getting. If it supports physical SIM, then you just have to move your current sim to the new phone.
