New Activation.
realhumera
Hello, I just ported my freedom number to Public Mobile. Everything is sorted out . I am just not able to receive the call to my number. I tried calling my number it goes to the voicemailbox. what should I do?
JacqueQ
I did my set up and port a few hours ago.  Took less than 2 hours for everything to work.
Hold on, just a little while longer.
realhumera
Thanks alot. I hope so.
Thank you.
Naepalm
@realhumera
I would wait until the morning. You will be so happy with Public Mobile compared to freedom!
have a great night
 You should wait a few hours. This is how number porting works. If someone calls you right now, it will ring on your Freedom service. Calls are likely going to voicemail because you removed the Freedom sim card from your phone.
fdrcamb519
@realhumera
Sometimes takes a few hours before number is fully working properly. All the best
