New $29 plan
cycling9
Can I switch from my current $35 plan to the new $29 month plan
2 REPLIES 2
SKSuh
Unfortunately PM usually makes it nearly impossible to downgrade an existing plan as they don’t wish us to pay less than we already do
TheSterlinger
@cycling9
When you sign onto My Account and click Subscriptions & Add-Ons then Change Subscription you will see a list of plans you can choose from, if the plan you want is not an option you cannot switch to it.
