10-20-2020 05:01 PM - edited 01-05-2022 03:49 PM
Cellular network fails to connect and disconnect unexpectedly. First time it disconnected, did a full reboot and reconnected fine. Second time it disconnected and won't reconnect.
02-01-2021 10:38 AM
I have the 2nd generation SE model MLXQ2VC/A. By now you probably realize that this has happened again. It's actually been a few months since I've lost network but never took the time to reach out.
I did try the sim card on another phone and connected without any issues. The SE is unlocked, I tried to reset network settings many times without success.
Any other ideas?
10-23-2020 12:02 PM
Here are my first gen SE settings......no issues at all
10-23-2020 07:44 AM
This is the first gen SE.
10-22-2020 08:58 PM
@denislegere wrote:I was finally able to make it work by resetting all network settings. Stay tuned if this happens again in a few months.
Do you have a brand new SE or the older one?
10-22-2020 08:20 PM
10-20-2020 11:11 PM
@denislegere wrote:Cellular network fails to connect and disconnect unexpectedly. First time it disconnected, did a full reboot and reconnected fine. Second time it disconnected and won't reconnect.
Hi @denislegere it seems that iPhone SE has many issues. This link might be of some help to you Apple iPhone SE Network Problems: No Service, Searching, Cannot Connect To Cellular Network
10-20-2020 09:42 PM
Hello @denislegere ,
Do you still have calling and texting ability?
If not, check your SELF SERVE account to see if your the 4 digits listed there match the last four digits of your SIM in your phone?
You can find this under "Change Sim Card" on your Overview account:
I would let the Public Mobile Moderators know about what is happening if your SIM does not match.
To contact the Public Mobile Moderator_Team, there are two ways to reach them:
1-Click the question mark on the bottom right hand side of your screen to talk to SIMon the chat bot or link: https://publicmobile.ca.ada.support/chat/
(if after clicking this you get an option to: Ignore OR Go to PublicMobile.ca – HIT THE “Ignore” option)
OR
2-Contact the Moderator_Team via private message using this link:
10-20-2020 07:14 PM
10-20-2020 06:28 PM
What generation of SE.?
10-20-2020 05:09 PM
I can understand your frustration with this. Have you tried updating your iOS first. I would also like you to try turning on airplane mode for 10 seconds then back off. Also, try removing the SIM card then reinserting it.
10-20-2020 05:08 PM
This sounds like a phone issue. Do you have another phone to try out the service on?
