Network Down?
blaze697
i was wondering if anyones network status is down, I cant make makes
2 REPLIES 2
blaze697
yes i did. then i noticed that my 3G setting was turned off for some reason...this was done not by me. Odd though, I was just using it just previously.
Anyways, I turned the 3G back on and it works
I'm on an Iphone 4, anyone else having or had this problem?
Cyber
@blaze697,
Function perfectly here in Montreal.
Did you try to reboot your phone ?
