Need help
Britaneefenwick
What do I do my phone says network locked sim card inserted and than it says sim network pin BLOCKED enter sim network PUK
@Jb456 wrote:
 network locked means your phone is locked to old carrier that you got phone from. You need to contact them and ask for Unlock code. It's free. If it's a Samsung phone.. go to Samsung Canada website and do a live chat with support and ask them
Sim network pin locked. Is usually 1234 for all carriers except freedom might be 0000
note: don't confuse sim network pin locked. To sim locked which is another lock that you can set a pin to lock the sim.
If you entered it wrong to many times...then it goes to PUK code.
For PUK code you need it from moderators.
Or private message at link below
SIM Network Unlock PIN and SIM Network Unlock PUK are not things that the Public Mobile's moderators can help with. The phone is locked to another carrier. Entering 1234 and 0000 will fail.
kselmak
Don't try entering wrong number too many times you can brick it
Contact manufacturer, that's the fastest route
Jb456
gblackma
@Britaneefenwick You need to get your phone unlocked by either the manufacturer or your old service provider . The phone is locked to your old service provider.
