03-10-2018 11:20 AM - edited 01-05-2022 04:25 AM
I activated my sim card 16 hours ago and still get ¨No Service¨. I tried to turn airplane on and off; I dont have another phone and I don't have another sim to play with. Please help! I´m using an iphone.
03-10-2018 11:45 AM
Thank you so much, I will do so!
03-10-2018 11:43 AM
Sorry we were not much help.
Just in case:
How can you get help with your account, activation, or service?
In your message please include:
Don't know your pin?--provide any 3 of the following:
How long until they reply?:
Additional Useful Information:
03-10-2018 11:40 AM
I ported my own number , it shows the selected plan, and phone is unlocked, re-started phone and still no luck. I will contact moderator, thank you!
03-10-2018 11:38 AM
It says account active
03-10-2018 11:33 AM
@Puravida66, did you take a new phone number, or did you port in your own number.
Also, does your self serve account show your plan as you had selected it.
Finally, are you sure your phone is compatible with Public Mobile.
If the phone is compatible and account is set up ok, and you took a new number, it should have been working within minutes. Did you do a full restart of the phone.
If yes to all of this, you need help from the moderator team. Send them a private message and they will help. Click here to send them a private message.
Information regarding the moderators team can be found by following this link.
03-10-2018 11:32 AM
Did you loginto selfserve? What does your plan say?
