NEED TO BLOCK MY NUMBER INFO ON CALLA
NEMISIS
NEMISIS
THANKS FOR YOUR HELP IT WORKED...
slusagm
Public Mobile does not send any name info.  If you meant you want to block this name info, they are actually from some number-name lookup app, not from Public Mobile
but if you want to even block phone number being send out, you need to do this
Per-Call Blocking:  Dial #31# before the 10 or 11-digit number you are calling.
Permanent Blocking: Dial *31# (you will hear a network tone, then the call will hang up) to make your number hidden for all calls.
Reversing Permanent Block: Dial #31# to set your caller ID to appear by default again.
Phone Settings: On iPhones, go to Settings > Phone > Show My Caller ID and toggle off. On Android, go to Phone App > Settings > Additional Settings/More > Caller ID and select "Hide Number".
@NEMISIS , Public Mobile does not offer any kind of number blocking.  Depending on which dialer app you are using, there might be settings to hide your number.
