07-17-2018 12:24 PM - edited 01-04-2022 06:27 PM
Only yesterday I was creating presentation and after worked with it all the day. But today I couldn't find my last slides that I hardly created. I didn't try to find powerpoint repair tool or something like. I don't have any spare time for this purpose, I hope it can be solved here. I'm on iPhone X.
07-23-2018 11:59 AM
Please try below article to make older presentation compatible with new versions of PowerPoint and check if that fix the problem.
Another good link:
http://www.pptfaq.com/FAQ00916_PowerPoint_won-t_open_my_older_PowerPoint_presentations.htm
Last one way might be special method for any gadget like phone, tablet and etc.
07-17-2018 02:38 PM
were you saving to the cloud?
07-17-2018 02:05 PM
Where is your presentation located usually?
When you access it, what error do you have? etc.
need alot more info before troubleshooting.
07-17-2018 02:03 PM - edited 07-17-2018 02:05 PM
I could be wrong, but this sounds like more of a iPhone presentation issue rather than something Public Mobile related,.
It might be better to try posting on the Apple community site.
07-17-2018 12:44 PM
It sounds as though you may have consumed all of your prepaid data. Try to connect to a wifi connection and see if that works. Let me know and I’ll help as much as I can.
Have a a good day!
07-17-2018 12:37 PM
Maybe you consumed all of your prepaid data.
Check your My Account for your usage to see. It'll tell you how much of your data you've used.
