01-06-2018 12:11 PM - edited 01-04-2022 03:15 PM
01-06-2018 06:03 PM - edited 01-06-2018 06:06 PM
MEP is a term used by Blackberry devices during the days of Blackberry OS. This usually meant that the phone is locked to another carrier. From what I recall, most of these devices required the MEP4 code, although I do see that you are actually asking about one of Blackberry's Android devices.
01-06-2018 04:55 PM
IWIK wrote:
Device from Telus so originally worked with pm? Then you for some reason were entering Network unlock codes and ran out of attempts? Or this is just a locked sim card?
Do you have a SIM from another provider that you can try? If that also doesn't work you may need to reach out to a Blackberry tech.
01-06-2018 02:27 PM
01-06-2018 12:57 PM
@will13am wrote:
@mimmo wrote:I did a quick search and found this site:
https://forums.crackberry.com/blackberry-priv-f440/my-priv-mep-locked-what-can-i-do-1079568/
sounds like a similar situation.
Well this is strange. If mep lock is similar to SIM lock, then why would the phone relock itself?
no idea, maybe like the samsung phones locking to first sim inserted? maybe it was not unlocked?? not a blackberry person so just throwing things out there? the link said after 10 attepts phone is perminatly locked but maybe blackberry can do something of phone was originally unlocked.
01-06-2018 12:38 PM
01-06-2018 12:30 PM
01-06-2018 12:26 PM
@Christiansaltswrote:It was working previously. I can still use the phone but i can't access the pm network. I couldnt figure out how to unlock my sim card basically and i think i tried 10 times to put in the pin. My phone is supposed to be unlocked, so i think it's a sim card issue. Although, i am not sure. Btw, it's a blackberry priv phone.
Sim cards are never locked. It seems like something wrong with your phone. Insert the sim in another unlocked phone and see if it works.
01-06-2018 12:24 PM
01-06-2018 12:18 PM
I have never heard of the term mep locked. Please explain the behavior in greater detail. Did this happen suddenly. Was the phone working previously?
