My data is not working
rumblefish
Can somebody please help me my data is not working on my nexus samsung just got the phone talk and text is working but not my data
rumblefish
Thanks Shawn I’ll try that
ShawnC13
@rumblefish, if you are new and your old provider was freedom you may need to do a network reset or even a factory reset to get your data working
* I am happy to help, but I am not a Customer Support Agent please do not include any personal info in a message to me. Click HERE to create a trouble ticket through SIMon the Chatbot *
torontokris
xCameron94x
When did you join pm? Can you log into self serve and check if you have any data left?
On the main page on self serve under "my plan And add ons" you should be able to see data usage. If you do not see any data there, it means you have used up all of your data. If you do see data usage there, you may need to check the APN settings
