My data add on is not working
JanineD
Purchased extra data and it is not showing up on my account. I have resigned in twice.
@JanineD if the refresh spinner didnt work, try to login My Account again using Incognito mode and check again.  Also, check Payment history page to see if it shows PM took the money and it was used towards the addon purchase
Ckk_2194
@Ckk_2194
OP did write they, "Purchased extra data"
Suppose it's possible they've already depleted it.
@JanineD , just to be certain, you're referring to data for use while in Canada and not a US data add-on?
Ckk_2194
Are you out of data if it is not working? If so you can go into your account and purchase a data add on  or dial *611 on your phone and follow instructions that they tell you
HALIMACS
@JanineD
Login using an incognito or private Tab and when on there, tap the little refresher icons to get an updated version of the page.
