06-15-2018 11:17 AM - edited 01-04-2022 06:11 PM
Hi everyone,
Starting from a few days I am unable to send MMS messages. I first thought it was a problem with the recieving end that the messages are not delivered, but now I've tried with several friends and every MMS I send it gives me an error (sometimes afer like one hour) that he message could not be sent. All of the MMS messages show "sending" as status until the failure occurs.
Do any of you guys encountered this issue? Any suggessions?
06-15-2018 01:16 PM
Hi everyone,
Thanks much for all your answers. Today I when through all my APN settings line by line and all of them were fine. Then I installed a different app for sending messages (Google Messenger) and tried to send MMS with it. Still didn't work. Finally I rebooted my phone and it started working again. 🙂
06-15-2018 12:03 PM
@Cheetah24, are you able to receive MMS? If not, then I suspect that APN settings is your problem. Follow this post to set up your APN.
If you are able to receive MMS but not send, it could be an app issue. Try going into the messaging app and clearing cache and data to see if that resolves the problem. If not, try a different messaging app.
06-15-2018 11:42 AM
Is this via iMessage? Does it happen when you’re on cellular, wifi, or both?
I have similar problems with iMessage on wifi occasionally. It can be super flaky.
06-15-2018 11:23 AM
Is your phone an iPhone or Android? (or Windows?
06-15-2018 11:21 AM
I had that issue when I first signed up with PM and the problem was with my APN I had a capital letter by accident
