09-08-2019 03:44 PM - edited 01-05-2022 06:57 AM
09-08-2019 04:27 PM
All variations of this phone will work with Public Mobile. Some of the LTE bands might not be supported on some models. https://www.gsmarena.com/motorola_moto_g7_power-9527.php
09-08-2019 04:09 PM
@rubs wrote:Is the Moto G7 Power compatible with Public Mobile?
According to the following check, none of Moto G7 Power versions are supported by Telus network. YMMV
09-08-2019 03:51 PM
09-08-2019 03:51 PM
09-08-2019 03:46 PM
@rubsIf it is an North American model you can verify by checking your model number usually starts with XT.. it will be compatible with Public Mobile (which uses Telus / Bell network)
