Moderator support
08-07-2018 06:43 PM - edited 01-04-2022 06:41 PM
How long does it typically take a moderator to respond to a private message? I have been waiting 5 days for my phone number to be ported over and I can’t get a response from a moderator. I’m not getting any indication that this support system has any merits and that problems could go unresolved indefinitely.
Phones
08-09-2018 10:04 PM
@Rustman1577 wrote:Yes. That’s who I sent it to. I guess I’ll wait a bit more. Using my old SIM card again. Paying for two services isn’t exactly cost effective though.
Patience is key! Moderators are always swamped.
08-07-2018 07:55 PM
08-07-2018 07:54 PM
Yes. To both those questions. Waiting for moderator support.
08-07-2018 06:58 PM
1. Did you initiate your number porting using the following PM page?
Plan and Add-Ons --> Change Phone Number --> Transfer a wireless or wireline number
2. Did you initiate your number porting during SIM card activation?
3. If you sent a private message to moderator team using the link below 5 days ago, you should get the response by now.
08-07-2018 06:46 PM
@Rustman1577 wrote:How long does it typically take a moderator to respond to a private message? I have been waiting 5 days for my phone number to be ported over and I can’t get a response from a moderator. I’m not getting any indication that this support system has any merits and that problems could go unresolved indefinitely.
Did yousend your message to @CS_Agent? It shouldn't take that long to receive a response - I believe 48 hours is usually the max amount of time to wait for an initial reply from a mod.
