01-19-2018 05:03 PM - edited 01-04-2022 03:21 PM
01-27-2018 07:22 AM
Thanks a lot. I just turn off the phone and it worked. Best regards
01-22-2018 03:39 PM
@velasgloria did you get this resolved? If not, we're still waiting for more info to try to help you.
01-21-2018 07:30 PM
@velasgloria you've given us very little to work with here. i'm going to assume you recently activated, and this phone has not previously worked with Public Mobile, since that seems to be implied. Did you verify it's compatible with Public Mobile? Please check using willmyphonework.net. If it is, could it be locked to another provider?
01-19-2018 11:58 PM
did you request your number to be ported over? Is your phone locked to another provider?
01-19-2018 05:07 PM
Hi @velasgloria. Do you have a new account? Or are you, perhaps, renewing your plan? Has the phone you are using previously been used with PM? With another carrier? Could you please provide additional details...
01-19-2018 05:06 PM
@velasgloria Can you please try the following:
- turn on the airplane mode for few seconds and then turn it off
or
- restart your phone.
Or
- turn off the phone
- remove sim card
- reinsert sim card
- turn on the phone
