06-27-2025
10:44 PM
06-27-2025
10:47 PM
computergeek541
06-27-2025 10:54 PM
just to add, in case you cannot properly login to open the preferred Chatbot ticket. you can message them here:
06-27-2025 10:47 PM
To contact support, customers need to open a ticket. That can be done through the following link: https://widget.telus.tiia.ai/chatbot.html?botId=ZJkWuVb7Hp6EEcTIZKMZbvLwuDV&duid=2OhrPakuMpNZt4irir5...
