07-20-2020 06:22 PM - edited 01-05-2022 12:31 PM
I would like to know why both phones that I have with Public Mobile, have stopped sending MMS pictures.
-We do pay for the service: Public Mobile $25.00 X2, per month.
-It was working directly after Public Mobile had been initiated, for a few days.
-The data is turned on both phones.
There isn't any reason why it should suddenly be disabled by Public Mobile, after working perfectly correctly once Public Mobile SIM had been installed/initiated.
Please resolve.
07-21-2020 04:33 AM - edited 07-21-2020 04:34 AM
07-20-2020 07:27 PM
Thank you, all. I tried resetting as per instructions. Also, taking out the SIM again, replacing and restarting. But, it still not working. I'll send for more help, thank you.
07-20-2020 07:17 PM
@Jway wrote:I would like to know why both phones that I have with Public Mobile, have stopped sending MMS pictures.
Please resolve.
Hi @Jway , please try the suggestions as others are posting and see if that fixes your problem. I hope it does!
If it does not you can contact the Moderator_Team to look into it by using this link.
07-20-2020 07:11 PM
@Jway Also make sure the APN Type contains mms as part of the string. If it doesn't just add it at the end of the current string as follows:
,mms
07-20-2020 07:03 PM
@Jway did you try the network reset? Restart you phone if it doesn't automatically do so. Stay safe.
07-20-2020 06:56 PM
Android. Samsung, S8.
I have taken the SIM card out and then replaced it then restarted the phone.
Still not working.
Thank you to the others, for chiming in. Much appreciated.
07-20-2020 06:42 PM
@Jway iPhones or Android?
07-20-2020 06:35 PM - edited 07-20-2020 06:36 PM
@Jway try a network reset and restart your phones if they don't automatically do so. Stay safe
07-20-2020 06:25 PM
@Jway Check your self-service account. Is it active? Autopay mail fails, so your account could be suspended. Maybe need to do manual payment. Try restarting your phone as well.
