07-28-2015 04:57 PM - edited 01-04-2022 12:41 PM
I have managed to send (but not receive) MMS messages on my flip phone. Since there is not a lot on this forum pertaining to non-smart phones this post is to document the steps it took so that anyone looking for help might be able to have a starting point for their phone. These steps are based on a LG A341.
You will notice very quickly that the order of these steps matter.
Legend:
Blue is the main menu.
Green are menu options in the bottom corners.
Set Up Access Point
Settings -> Connection -> Access Points -> New
Connection Title: PM
Authentication: No Auth
APN: sp.mb.com
Save
Set Up Internet Profile
Settings -> Connection -> Internet Profiles -> New
Profile Name: PM
Use Proxy: Off
Access Point: PM
Save
Set Up Message Center
Messaging -> Message Settings -> Multimedia Message -> Message Center -> Options -> New
MMSC URL: http://aliasredirect.net/proxy/mb/mmsc
Internet Profile: PM
Save
Activate *This is very important and easily overlooked*
Restart Your Phone *also easy to overlook*
As mentioned above I can only send not receive picture messages. I will update this post when/if I manage to get the receiving half working. Also if you have different steps for your make/model of non-smart phone I will gladly add them.
12-27-2019 06:42 AM
Glad you found a post from 2015 to be helpful.
Who would have thought these phones would still be in use today!
12-27-2019 05:24 AM
@computergeek541 wrote:That phone brings back some memories in the sense that I remember a few years back that a store would have doorcrashers for that model selling them for $8 each..
battery lasts over a week on stand-by! 🙂
12-27-2019 12:29 AM - edited 12-27-2019 12:48 AM
12-26-2019 09:38 PM
These instructions helped me setup an LG C441 / F4NR. Thank you!!
05-10-2019 10:11 PM - edited 05-10-2019 10:14 PM
@geopublic wrote:
@dumbphone wrote:this thread is about dumbphones non smart phones (without wifi)
If your phone has a browser then it should support WiFi.
@geopublicplease go "should" deserving smartphones in another thread where your comment fits. The models here were mentioned from the get go here. These kinds of dumbphones have browsers and support mms but do not have wifi regardless of what you think they "should" have
05-10-2019 10:05 PM
@dumbphone wrote:@geopublicthis thread was about dumbphones/non smart phones (without wifi) in my case
Ok.
05-10-2019 10:05 PM
05-10-2019 10:00 PM - edited 05-10-2019 10:05 PM
05-10-2019 09:54 PM
@dumbphone wrote:Using this thread and another I got the MMS inbound and outbound working now.
but the browser still disconnects on launch
the menus are exactly as the first post described
Does the browser work when you are on WiFi?
05-10-2019 09:45 PM - edited 05-10-2019 09:47 PM
05-10-2019 12:08 PM
@dumbphone wrote:are the settings changed? I can't get this to work
@dumbphone Maybe post some screenshots of your APN settings so that we may be able to help you. ![]()
05-10-2019 11:52 AM
Did you recently renew? Does browsing work?
05-10-2019 11:51 AM
07-29-2015 01:20 PM
07-29-2015 12:31 PM
You are completely correct. Possible yet unnessisarily difficult.
Thanks! I hope to figure out the recieving part soon too :).
If you refer to the "dumb phone" tag. Its compeltely thanks to @chukdefatey as that's how he refered to it when he replied to me as i was trying to figure it all out, i hadn't thought of them that way until then.
07-29-2015 05:49 AM
07-28-2015 05:10 PM
Completely agree with @Martin. Great initiative @Charanth182 - this really will be helpful for customers who aren't using smart phones and wanting to use MMS.
In addition, I must confess that the choices of tags in your post made me smile ![]()
07-28-2015 05:03 PM
