10-22-2019 02:02 PM - edited 01-05-2022 09:31 AM
Hi guys, I've been with Public Mobile for about 18 months and my loyalty rewards is still only $1 off each bill, anyone know why this may be? Any help is greatly appreciated, thanks.
10-24-2019 12:07 PM
Ah I see, I misunderstood it, I thought it was after your first year, each month you get an additional $1 off, and then after the second year, you get $2 extra off each month. (so say after the 2nd year and 1 month, you'd be saving $14/month) but I guess that would be bad business haha. Thanks!
10-22-2019 05:47 PM
In order to recieve $2.00 of loyalty bonus, you need to be a member for 2 years. You must be in service this entire time as well. If you go inactive for a month, it will reset.
10-22-2019 02:09 PM
Each year you are with PM you get $1 reward per month, so you will get your next reward increase at 24 months. Cheers
10-22-2019 02:07 PM
Are you on a 30 day plan ? If so it is $1 after 12 months and does not change until after 2 years.
https://www.publicmobile.ca/en/qc/get-help/articles/the-loyalty-reward
10-22-2019 02:07 PM
@Jkharris, you should switch to $2 in loyalty rewards after completing 2 full years, that is 365 days x 2. So, it would take 25 x 30 day periods to reach that point or 24 renewals not counting the initial activation as a renewal.
