Lost sim
stveyo
So I recently lost my current sim card when I removed it during travel in a foreign country. I lost that card and I want my plan and phone number back, and I already have another public mobile sim card that is unregistered. So my question is how do I replace I unlock this new sim with my previous plan and phone number?
2 REPLIES 2
MacMe
Log into self serve, click on the "Plans and add-ons" tab, then "Change SIM card".
You could use this direct link after you log in:
https://selfserve.publicmobile.ca/Overview/plan-and-Add-ons/change-sim-card/
smp99
Simple - log into your account. There is an option to change SIM. Follow instructions. You can find the link on the first page after you login on the right hand side
